Hybrid Modelling (R14)
We have just switched to R14 from R12, and have been looking at the various new commands and functionality.
I have noticed that by enabling hybrid modelling when creating a new part that elements such as surfaces etc are included within the part body tree.
Has anyone found any use for this (rather than just using open bodies), apart from creating a very long part body tree??!
RE: Hybrid Modelling (R14)
Two benefits of using hybrid design are:
1. all construction geometry is located in the same part body as the solid (and geometric sets can be added inside the part body) making it easier to understand how a part was made
2. it forces users to structure the geometry in the tree in a heirarchical order
Jack
Some utilities only work with Part Bodies, so you have access to surface geometry if you use hybrid design. (I don't remember which utilities)
We're using R15 now, and we have not seen any negative impacts by using non-hybrid and hybrid CATParts.
Once a hybrid part is created, it is very difficult to convert it back to non-hybrid.
Jack
K. C.
Although I acknowledge that there may be a benefit for some users to have the functionality you have described, I can't see any major benefit for the type of work my colleagues, given the work we are currently undertaking.
Thanks all the same
It allows me to keep better track by keeping all according geometry in the same "layer" (body or geometrical set).
Since layers are no longer used, this is a good alternative for us.
