pro|program question
hey a braincracker here... for me at least :)
i made an assembly with 8 sub assemblies. it's a trashreceptor (a large street-model) the design is a modular one so they are connected next to each other or they can be stand alone. (i hope this is a bit clear)
the modularity doesnt stop there, inside the trashreceptor, i can choose for a glass-module (shredder) a plastic-metal-module (press) and a paper-module.
my question now is: is it possible to make a program, that once run, it asks how much modules you want, and afterworts asks which module i want to put in each of the modules.
i made my assembly so, that i have 1 complete module, with all the modules in subassemblies.
i know how to make the program to choose wich module but can't think of a way to make the program ask how much modules i want...
if anybody can help, even just a little tip to get me started, or a place where i can find more explanation?
big thanks in advance,
if there is not enough info, or if something isn't clear, ask away, i knkow my english isn't that good
greetz
tonton sam
greetz
tonton sam
RE: pro|program question
Make a parameter that is an Integer, and this becomes the amount of modules you need. In Pro/Program, include this paramater as one to be entered when you regenerate the assembly, and simply enter the desired value.
As a tip, set limits to the interger range, so someone does not enter 10000 or -1 units or something like that.
I hope this helps out.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
