Cleaning Off Mill Coolant
Can anyone recommend a cleaner (solvent or other) for removing a emulsified mineral oil (a CNC milling coolant)from a polished metal?
RE: Cleaning Off Mill Coolant
Simple Green!
Works great, is biodegradable, non-flammable...
The only problem is that it leaves virtually nothing on the surface of the steel, so if not protected they'll rust.
I've had good results with Dawn dishwashing detergent.
