Earth ground resistance methods
Can someone explain the advantages of using  the "Fall of potential" method to measure earth ground resistance over any other methods.
RE: Earth ground resistance methods
If you register at this website you can download an explanation of fall-of-potential method:
http://www.megger.com/common/documents/NETA-Ground.pdf
It's generally considered the most reliable method of determining earth resistance because it provides a method of accounting for other resistances in the test setup.
