Stresses in triangular plate
Does anyone have references for calculating the stresses and  the deflections in a simply supported triangular plate under uniform loading or pressure?  My Roark's only has round and parallel edge supports.  Thanks!!
RE: Stresses in triangular plate
My copy of Roark & Young (5th edition) in Table 26 has cases 17 and 18 for triangular plate with simple supports.
-Mike
Any chance you could scan it?
I am using MathCAD's extension pack and it does not have this load case.
IFRs,
I'll be out of the office until late tomorrow afternoon.  If I don't see anything posted by then I will try to get it scanned.
-Mike
The basis of Roark's formulae is the Timoshenko, art.72.
prex
http://www.xcalcs.com
Online tools for structural design
IFRs,
I have not been able to get a good scan off the equipment I have.  If you still need it, maybe someone else can help.
-Mike
Mike -
If you can, I would appreciate it very much.  If not, I understand and thank you for your efforts to date.
Allen -
Your demo only does rectangular supports, but thanks anyway!
from Roark 7th Ed, table 11.4.17, pg519
for an equilateral triangle, simply supported sides, constant thickness, with a uniform pressure load
maximum stress = 0.207q*((L/t)^2)
where q = applied pressure
and L = side length
(the equation is in terms of a, the perpendicular height, = L*sqrt(3)/2)
and max displacement = -0.019q(1-nu^2)L/E*((L/t)^3)
nu = 0.3 ... (1-nu^2) = 0.91
IFRs,
I just sent two scans to the email address in your profile.
The quality is about the best I can do.
Hope it works.
-Mike
rb1957 and Mike - I appreciate your efforts very much.  Stars to follow when I get home and have more than 10 seconds of battery life
