water hammer guides
water hammer guides
water hammer guides
where can I get good advice to solve water hammer problems?
RE: water hammer guides
BenThayer (Chemical)
Just one comment on your referenced website.
It refers to quick closing valves.
What is quick closing really relates to the length of pipe up or downstream from the disturbance.
 Considering the sound speed for a liquid as relatively hign compared to the local fluid velocity
-- a quick closing valve is one that closes in a time less than or equal to
2L/c
where  L would be the length upstream of the valve and c, the sonic velocity of the liquid.
Fluid Transients in Systems Streeter and Wylie
Fluid Transients in Pipeline Systems ARD Thorley
Pressure Surges in Pipe and Duct Systems Swaffield and Boldy
 Also see Risk paper on Surges at www.pipingdesign.com
