EN 10028/3 P355
EN 10028/3 P355
Good morning,
can you give some infos about this material,please?
I mean SMYS,STMS and everything concerns tension.
RE: EN 10028/3 P355
P 355 is used for pressure vessels with a minimum yield strength of 355
N/mm*mm for t<16mm.
The German standard number is 1.0562
A steel with a similar chemical composition would be a ASTM A 633 Grade C.
Behind the designation P 355 are usually keywords given that clarifys the treatment of the manufacturer.
Hope this helps
