FLOW MEASUREMENT
FLOW MEASUREMENT
FLOW MEASUREMENT
DEAR EXPERT,
WE ARE LOOKING FOR A FLOW MEASURING DEVICE WHICH IS PORTABLE,WE ARE NOT ABLE TO PROVIDE ANY HOLES ON THE PIPE FOR MEASUREMENT LIKE OUR PITOT TUBES.
WE SHOULD BE ABLE TO MESAURE DIRECTLY FROM OUTSIDE OF THE PIPE WITHOUT CONTACTING THE WATER FLOWING INSIDE.
IT SHOULD BE ABLE TO MEASURE FROM ID 100 TO ID 1000 MM.
KINDLY ADVISE.
REGARDS
VRL3
RE: FLOW MEASUREMENT
vrl3,
  Please check this web www.techrentals.com.au you can ask them for your need.The brand Panametric Pt-868,good value
 good luck,
arzelan
Consider a portable clamp-on ultra-sonic flowmeter. I have had good experiences in the past with Controlotron. Provided they are installed as per mfr recommendations and the proper data has been entered into the flowunit flow accuracies of down to a few percent in the turbulent flow regime can be attained.
Dear Dick van kampen,
Thank you very much for your reply, kindly let me know what will be the approx cost of this equipment.Please let us know the contact address or e-mail of the controlotron manufacturers.
Bye
vrl3
With the risk of beeing crude:
Why havnt you tried www.controlotron.com ?
You can locate reps. on their homepage
Best Regards
Morten
