Overhead Lines
Overhead Lines
I am in the process of reruiting a number of 4160 distribution lines. I am finding it difficult to locate the current rating of various ACSR conductors. If someone could point me in the right direction it would be appreciated. Also, what is the usual acceptable temperature rise in overhead lines, and where could one find a set of tables with various ampacity vs maximum temperature?
RE: Overhead Lines
RE: Overhead Lines
http://ap
RE: Overhead Lines
RE: Overhead Lines
One thing to consider is that at the 90C rating, you will have greater sag in the conductor so you need to design that in to you job.
RE: Overhead Lines
RE: Overhead Lines
