array return in matlab
I am new to MatLab.Please help..
What will the following code generate?
assuming we have data points(0.8,0.5,0.7,0.5,0.3..) between sr(1) to sr(50)
sr=[1 50];
[Y1 I1]=min(abs(data(sr(1):sr(2),:)-0.5),[],1);
Will it first take the absolute difference between data value and 0.5 and return those indexes of I1 for which this difference is minimum.Say I1(4),I1(9)...I1(45) etc.
RE: array return in matlab
You are supplying possibly greater than a vector and asking a question about a vector.  Please, define the problem as a vector only and rephrase the question.
You said this:
but then gave a code sample that was inconsistent with your question and explanation above:
 data(sr(1):sr(2),:)
Can you rethink or rephrase with only 1D going into your min function?
