Ball Bearing Stiffness (horizontal and vertical)
As you may know, there are equations for ball bearing stiffness calculations in radial and axial directions. The radial direction is actually the load direction.
Does anybody know (or anywhere to look for) the ball bearing stiffness calculation for horizontal direction, i.e. perpendicular to both load direction and axial directions?
Thanks.
Thanks.
RE: Ball Bearing Stiffness (horizontal and vertical)
"Rolling Bearing Analysis", Chapter 9.
Lots of luck. It would be easier to have
the bearing manufacturer do this for you
and you could do it yourself to confirm
the procedure.
