Develop threshold for an analog signal
I am looking to develop a threshold condition (upper and lower boundary) for an analog signal.
Say I have an analog signal and I want to develop an offet around the signal. The trick is not only to add and subtract an offset of a fixed magnitude around each data point, but for each of the threshold signals (upper and lower), the slope of the line joining two successive points should be the same.
Also, the analog signals obtained for the positive and negative threshold should have the same number of data points as the original analog signal.
-Dude
-Dude
RE: Develop threshold for an analog signal
You can certainly do a running calculation of rms deviation.
TTFN
-Dude
Pd -- probability of detection
RMS -- look in your statistics or math book
TTFN
dataAnalogSampled = randn( 1, nData );
thresholdHigh = dataAnalogSampled + 1;
thresholdLow = dataAnalogSampled - 1;
But this seems like a meaningless excersize, changing the threshold point by point once ou know the point. What am I missing?
