pressure on arch unit due to backfill material
Can someone help me to find the spread sheet for calculating the pressure on the arch unit due to backfill material.
RE: pressure on arch unit due to backfill material
Wes C.
There are no engineers in the hottest parts of hell, because the existence of a 'hottest part' implies a temperature difference, and any marginally competent engineer would immediately use this to run a heat engine and make some other part of hell comfortably cool. This is obviously impossible.
