Checking in FEA results
Does any one know how to check in FEA results and keep the file size down? For instance, I have a part size of 1 meg. and the FEA file size is 40 meg. Is there a way to reduce the 40 meg?
RE: Checking in FEA results
your output selections tab is under solution set in model solve. You can deselect some but not all outputs. this might reduce the results set size.
good57morning@netzero.com
