steel composite design
I've heard that shear studs should not be used on steel beams with webs that are less then 1/4" thick. Is there a reason for this that I am missing? When I run software on these designs, overstresses do not show up.
RE: steel composite design
Be careful! We have had the experience on one project where the erector was not directly over the web, he burned thru the flange (on a beam whose flange was less than that requirement).
