strength to weight ratio of steel
can anybody tell me what the strength to weight ratio of grade 43 steel is?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: strength to weight ratio of steel
Ciao.
"Grade 43 is an old number for structural steel acc. BS.
It is now called S275.
Tensile strength 410-560 Mpa
Yield 275 Mpa (for tk up to 16mm)"
so which temper are you using ?
and what strength ... tension, compression, bending ...
If you are looking at it from a design point of view, i.e bending, shear, tensile, compression in structural members you could look at BS 5950 Structural use of steelwork in building. This is a British Ultimate Limit State design code.
