Problems with Macro to Build an Assembly
I have recorded the following macro in which I added a part called "Face.SLDPRT" at the origin in an open blank assembly file.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Dim FeatureData As Object
Dim Feature As Object
Dim Component As Object
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Part.AddComponent "C:\Face.SLDPRT", -0.001940447873138, 0.005483874424086, -0.01049999999998
End Sub
When I open the blank file a 2nd time and run the macro, nothing happens.
The assembly file and part file are in the same directory.
Any suggestions as to what is wrong?
RE: Problems with Macro to Build an Assembly
My guess is that the problem is coming from the Part.AddComponent command
After the macro has run, the assembly is still blank.  Nothing has been added to the tree.
Anyone have any suggestions?
By playing around with this, I have learned that the macro will work if the assembly file has at least one part loaded in it.  If the document is blank, the macro will not add the first part.
Can anyone provide me with insite how to load the first part automatically as well?
Spurs,
If you read the remarks in API help for AssemblyDoc::AddComponent:
Quote:
The specified file must be loaded in memory. A file is loaded into memory when you load the file in your SolidWorks session (SldWorks::OpenDoc) or open an assembly that already contains the file.
Thus the macro will not work correctly because the file is not loaded into memory.  Try the following by adding the code shown in red to your macro.
CODE
Dim swApp As Object
Dim Part As Object
Dim InsertPart as Object
Sub main()
Set InsertPart = swApp.OpenDoc("C:\Face.SLDPRT", swDocPART)
Part.AddComponent InsertPart.GetPathName, -0.001940447873138, 0.005483874424086, -0.01049999999998
'clean up - close inserted part
swApp.CloseDoc InsertPart.GetPathName
End Sub
Since you did not indicate which version of SolidWorks you have.  I tested the macro in SW2004, SW2005 and SW2006.  It works in SW2004 & SW2005 but in SW2006, the assembly does not rebuild correctly and would need a few more lines of code.
Regg
To get the code to work properly in SW2006 add the code in red.  You should probably add the code for the previous versions too.  Makes it more stable.
CODE
Dim swApp As Object
Dim Part As Object
Sub main()
Part.ForceRebuild3 True
End Sub
Regg
Regg
Thank you for the help.  Your suggested changes worked perfectly.
I am using SW2005.  Any idea what the changes are to 2006 for when I upgrade?
Spurs,
Read my second post.
Regg
