Powertrain component weights
From homebuilt aircraft sites - an automotive engine weighs ~ 2lbs per horsepower.
Questions
1.What does a fwd transaxle weigh ~ lbs/hp ?
2.Has there been any general weight reduction/hp in the last 10 years?
3.Is there any general powertrain weight differences between a fwd and a rwd system?
4.Any differences in domestic vs foreign weights?
I am interested in 100 and 200 hp powertrain systems.
Comments please.
RE: Powertrain component weights
2) hp has increased faster than weight has
3) a rwd has a propshaft, which weighs 10-15 kg at a guess
4) varies. If you want power / weight then you are looking for a turbo.
By the way, you need to define powertrain, it means different things to different people.
Cheers
Greg Locock
SBC ~350, 4 barrel carb, wet sump ~685 lbs. 250+hp @ 4200 and 185 @ 2200 used in a pre war experimental biplane fighter replica. It flew well enough but was not aerobatic.
Corvair, don't remember the size, turbo, Carter YH carb, weight a bit over 400 lbs. power was in the area of 200 hp in the 4000 rpm range and I don't recall what it was at 22/2400 but a guess would be more than 100 and I never saw it's application.
Nissan V6 turbo engines in a Burt Rutan racer. Both engines were fuel injected and turbocharged. If Rutan chose these engins as the optimum auto application for a aero racer, I just gotta go along with him !
Not much help, I know. Just some FYI stuff to ponder.
Rod
