cloud to solid
cloud to solid
cloud to solid
is there a way  if you have a cloud file
to transform them to a solid
i can transform them to   iges  or step
but when i import it like a program for aerodynamics  it keeps saying
it not a solid
its not a volume model
what to do to solve this
RE: cloud to solid
Do you mean a cloud of points?
RE: cloud to solid
have been sick   sorry
yes lordraille
yes i mean cloud of points
and the use is to modify the solid in differant ways
like bending and so on
hope anyone can help me with this
i  always get a empty solid
its like only discription of the geometry  nothing else
RE: cloud to solid
You need the Digitized Shape Editor license to work with this type of data.
The object in the tree is called "geometrical element."
Check out CATBlog!
RE: cloud to solid
well we have that but still its stays a dead solid!
or are we doing some thing wrong then?!
RE: cloud to solid
You shoud use the DSE and quick surface reconstruction workbenches to create lines, 3d splines sections and surfaces out of the pointclouds, and then use those surfaces to replace faces of the solid were needed.  TO import the point cloud you should do it from the DSE workbench as a ASCII file or txt or igs... using the import tool.
In the DSE workbench you can clean and work the clouds, and the QSR will help you creating geometry from the cloud.
also when you have the cloud properly cleaned, you can fit geometry to it using the fit to geometry tool from the freestyle workbench.
Hope it helps
