? ASTM A105 vs ASME SA105 ?
What is the difference between ASTM A105 and ASME SA105 ???
Thanks for you time
Thanks for you time
? ASTM A105 vs ASME SA105 ?? ASTM A105 vs ASME SA105 ?(OP)
Thanks for you time Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: ? ASTM A105 vs ASME SA105 ?
Gunnar
Everything above is correct, however what is missing is the reason for the distinction.
ASME "SA" materials are permitted for use as components for ASME pressure vessels...... for example, one would expect to see SA105 carbon steel components on a vessel drawing.
ASTM "A" materials are permited for use in a Power or chemical process plant piping system designed to ASME B31.1 or B31.3.
Material Records must be maintained by the vessel fabicator for all "SA" materials......... the piping system fabricator must only supply evidence, in the form of a certificate of compliance, that the materials meet the "A" requirements.
Hope that this helps..............
MJC
This is very interesting. I would like to know where this information is referenced. This could prove very useful in my job.
Lala
