opening V.16 part with V.15
I can't seem to open a SE part (drawn with V.16) with the older SE version V.15. I tried to export the V.16 part to IGES format and then open it with V.15., but the history is lost. Any ideas?
Duc
Duc
RE: opening V.16 part with V.15
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
There must be some solution to this problem, it appears that you can preview the SE V.16 part in window's environment, but can't seem to open it with SE V.15. Does anybody have any tricks?
If you only want to view the file, try using Solid Edge Smartview. I think this will open any version.
It should also work for viewing and printing draft files.
bc
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
