AutoCAD 2006 Delete/Add Row in Table?
Hello.
I'm wondering if there is a way to add/delete rows in a table using the command prompt or something OTHER than the right click menu (it is disable for most of my users) or is the right click menu the only way?
I might have to write some code if I can't get a solution.
Matt
Matt
RE: AutoCAD 2006 Delete/Add Row in Table?
"Everybody is ignorant, only on different subjects." — Will Rogers
Matt
I just came across this and it may be of use:
http://www.cadig.com/products/tablebar.php
