Megger testing procedures
3
I've been asked to find an IEEE or equivalent test procedure for meggering from the T-leads in an MCC cubicle to the motor in the field.  Any help would be much appreciated.
Ben
RE: Megger testing procedures
What is the operating voltage of your cables?
Benjamin Lanz
Vice Chair of IEEE 400
Sr. Application Engineer
IMCORP- Power Cable Reliability Consultants
NFPA 70E should help you also
Start each day off with a smile
,,, then you've at least that much out of the way!
I think you meant to say NFPA 70B
Scott Peterson
Training Manager
Power Plus Engineering
www.epowerplus.com
This is what I refer to when asked. There may be changes (Rev's) but pretty standard for Rotating Equipment and Cables. Corrections welcome.
IEEE STANDARD 43-1974 (29) ACCEPTANCE CRITERION FOR INSULATION
For Rotating Equipment
•IR is equal to or greater than 1 Megohm plus rated equipment KV.
MEGGER
IEE STANDARD NO. 43.1974
ACCEPTANCE CRITERION:
•IR IS EQUAL TO OR GREATER THAN 1 MEGOHM + RATED KV.
MOTOR RATING VOLTAGE    DC MEGOHMETER (Test Voltage)
460/575                                500 or 1000
2300/2400                             1000 or 2500
4000/41602                            2500
6600/6900                              5000
POLARIZATION INDEX
PI = IR Measurement at 10 minutes
     (Divided by)IR Measurement at 1 minute
Usually 2
IEEE STANDARDS: 690-1984(1), 422-1986(43), 43-1974 (29)
(for cable Insulation testing)
Again,  I do not completely understand the application.  However, I will give a warning that the IEEE standards noted are not applicable for shielded MV cables with extruded insulation. Per IEEE 400-2001 DC should not be used as it can damage aged cable and will not detect most defects.  I recommend at least a AC withstand or, better yet, a PD stress test.  Let me know if you have any questions.
Kind regards,
-Ben
Benjamin Lanz
Most of the regs that I deal with is 2 X operating voltage + 100v
