Corona Discharge Phenomenon
What is corona discharge? What causes it to happen?
Corona Discharge PhenomenonCorona Discharge Phenomenon(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Corona Discharge Phenomenon
Corona Discharge occurs when you get a high enough potential at a point to ionize the air around that point.
Air molecules are a reasonable insulator however the do contain quite a few free electrons.
Get those electrons exited by a high changing voltage and these 'bump' into neutral molecules causing them to lose or gain electrons. As the lose or gain electrons they become -ve and +ve ions giving of light. Most of the time you see a blue glow at the point of isonization as this is due to the prescence of -ve ions. Also Ozone is produced at the point.
Now give that isonized air a path to flow to (a nearby earth point) and voila discharge. The higher the voltage the further this distants should be between points to prevent discharge (or you could increase the insulation resistance)
Any help ?, yes no let me know.
if for example...say in a system and corona tracking is not found and corrected..the buildup of leakage paths can result in a line to line or line to ground flashover...the corona discharge and surface leakage at the barrier were probably due to a build up of conductive deposits on the cable sheath and the insulating barrier..
and don't forget...an annoying problem associated with corona is radio or communication interference..
there should be some good books on your library that will give you more descriptions and maybe pictures of this phenomena..
'hope this helps..
best regard
dydt
