Cold working Music wire ASTM A228
We are coiling a compression spring with a 25 spring index
and the springs ends on some of the springs are not closed to the coil, but seem to be slightly open. What would cause this? My opinion is that the wire has a poor cast or helix.
RE: Cold working Music wire ASTM A228
Have you checked C&H? You should at every set up so that you know. If you develop a problem you can check it again.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
