plexi glass structural properties
Does anyone have info on the structural properties of plexi glass?
much apreciated
RE: plexi glass structural properties
You should contact the manufacturer. They would probablly have the best data.
Wes C.
Thanks wes616, but I don't know of any manufacturer. The design will be done before a mfr is chosen.
I also recommend you contact the manufacturer.  If you don't have one chosen, dig in the phone book or the net and call around to a couple.  It might be on the net somewhere anyway, have you "Googled" it?
I've googled it and managed to get a few results:
bending stress of 11 ksi,and a youngs modulus of 450ksi.
I've also contacted a few manufacturers, but no replies.
If you sound interested in a product, any sales rep should jump all over to get you the information you need.
Those values sound good to me...
Generic Values for Acrylic are
Sut = 10Ksi
Suc = 18Ksi
Wes C.
There are no engineers in the hottest parts of hell, because the existence of a 'hottest part' implies a temperature difference, and any marginally competent engineer would immediately use this to run a heat engine and make some other part of hell comfortably cool.  This is obviously impossible.
