V5 drawing from CGR / large assy
To make drawing (even section cuts) of largy assy or CGR files, you can use the approximate drawing option :
Option/mechanical design/drafting/view/view generation/approximate
It will avoid a lot of crash and "command interrupted" !
(V5 can not deal with more than 1G/1.5G of memory)
RE: V5 drawing from CGR / large assy
It's what you see when you are in visualization mode, for example. It's just a graphical representation of the actual geometry.
Lee
http://www.lmco.com
Because when I create a section view from cgr-files (approximate view) I get the message "Your profile will not be associative"
Is this a setting problem?
