Taylor Number Definition???
I'm trying to do rotating cylinder-in-a-cylinder heat transfer design & am finding generally two different definitions for Taylor Number.
One is basically porportional to Reynold No., & the other to Reynolds Number ^squared.
The GE heat transfer book, et al, use:
Ta = [omega*radius*gap/kin.viscosity] * sqrt [gap/radius]
~Re*sqrt(gap/radius)
whereas others {i.e., Becker& Kaye, ASME Jnl H.T. may '62, et al.] use
Ta = [omega^2 * radius * gap^3]/kin.viscosity^2
~Re^2
where omega = rad/sec
These are then used to find the Nusselt No. & thence "h."
Can anybody shed some light/wisdom on this?? [The more I look [articles, internet], the more I find of either one or the other.]
Arto
RE: Taylor Number Definition???
Although I haven't been involved with heat transfer of rotating fluids, from reading relevant material it seems that the Ta/Re relation depends on the flow régime.
arto,
No help, but this a similar problem to one that gave an extra point on a final. A glass wine bottle in a metal Dewar with slush ice. What is the optimum speed to rotate the bottle to get the wine cooled to serving temperature in the quickest possible time.
don't know... maybe this is just an algebra problem?
calling the OP expressions...
Ta.  = [omega*radius*gap/kin.viscosity] * sqrt [gap/radius]
Ta.. = [omega^2 * radius * gap^3]/kin.viscosity^2
to make expressions shorter i use the following nomenclature:
w = omega
r = radius
t = gap
n = nu = kinematic viscosity
Ta.   = ((w*r*t)/n)*(t/r)^0.5
squaring Ta.
Ta.^2  = (w^2*r^2*t^2/n^2)*(t/r) = Re^2*(t/r)
Ta.^2  = (w^2*r*t^3/n^2)
then,
Ta.^2 = Ta..
so, the last expression should say...
Ta.. = Re^2*(t/r)
which is ~ Re^2 if t~r (t/r ~ 1)
the square of an adimensional number is still adimensional
so may be it has no influence in the end result...
what do you guys think?
saludos.
a.
except if the Re's ~ 1000, then Re^2 ~ 1000000
agree of course, it is up to the reader to determine if it makes sense or not.
saludos.
a.
To abeltio, when making H/T calculations for the Nu dependence on Ren the value of n could be, for example, 0.3 and 0.15, or 0.5 and 0.25, depending on which Ta has been selected...
Hasta pronto.
