Volume expression
Volume expression
Volume expression
I have extracted a solid from the inside of a tank.
Can I somehow export the volume of this solid to an expression ... via a spredsheet ot whatever?
RE: Volume expression
The mass3d function will do that in the spreadsheet.  Check the help files for all the options available for it.
-Dave
Everything should be designed as simple as possible, but not simpler.
In NX3 you can save the results of "Analysis > Measure Bodies" to the expressions.
