Flitch Plate/Beam Design
I have designed flitch beams for residential construction for 10 years, but have not located any useful references specifically related to this subject matter. Should anyone know of good design literature on this subject, such information would be greatly appreciated. Thanks. John
RE: Flitch Plate/Beam Design
"Wood Engineering and Construction Handbook" by Faherty & Williamson
and
Timber Design and Construction Handbook bt Timber Engeneering Company.
Both are available on "out of print" search engines.
Both are published by McGraw-Hill and are very good references.
A building control officer, who will remain nameless, is insisting that "in his experience" the plate I have used is not thick enough but he refuses to back this up with any calculation.
Did you find any good literature following your previous query? If so I could do with a copy to appease aforementioned annoying b.c. officer!
