Formula for the Equivalent Diameter of elliptical pipe
A source would be appreciated. Thanks.
Remember: The Chinese ideogram for “crisis” is comprised of the characters for “danger” and “opportunity.”
-Steve
RE: Formula for the Equivalent Diameter of elliptical pipe
Rh = cross sectional flow area/wetted perimeter
Ref: Flow of Fluids through valves, fittings and pipe
CRANE
Technical Paper No.410
saludos.
a.
Approx perimeter of ellipse = pi( ((3*length)+(3*width)) - sqrt((length+)+(3*width))*(width+(3*length))) )
Hydraulic Radius = Area / Perimeter
Or something like that...
Thanks for pointing out that I'd used ellipse "diameter" as opposed to "radius" in my equation, giving an area four times the size it should have been!!!
Brian
