Editing Dims
Editing Dims
Editing Dims
I have a drawing that won't let me edit Ie.... add "2X" or any test to the Dim.  The dims are imported from a model that has several configs.
Any help?
Ed Hulse
Sr. Designer/DBWorks Admin
RE: Editing Dims
Is the file set to Read Only?
Is it a SW file (.slddrw)?
Do you also have the associated models?
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: Editing Dims
1. no
2. yes
3. yes that has several configs
If you double click and try to change the length it says something about active config.
2005 SP4.0
Ed Hulse
RE: Editing Dims
What release and service pack are you running?  I had that happen to me in an earlier 2005 SP but it was fixed in SP 4.0
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Just because I'm paranoid doesn't mean that they aren't out to get me.
- Woody Allen
RE: Editing Dims
Manually putting them in is the way I do it....but this is a co-worker that has to have them improted, so he thinks.
Ed Hulse
RE: Editing Dims
Ed,
Check this thread I started when I was having the problem
thread559-120509
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
      o
  _`\(,_
(_)/ (_)
- Woody Allen
RE: Editing Dims
If it says you can only modify the active configuration, then it isn't a driven dimension.  Try right-clicking it and picking "driven".  You should now be able to modify it.
Flores
SW 2005 SP 4.0
RE: Editing Dims
Instead of changing the dimension state (Driven vs Driving), just activate the configuration you are trying to change. You should then be able to do the changes.
RE: Editing Dims
Ed,
If the dim is imported from the model, edit the dim in the model and add the "2x" text after the <DIM>. This will show on the drawing.
Jeff
RE: Editing Dims
This is an example of the macro code I use to make the configuration the active without having to search and  without leaving the drawing (you must first select the view):
CODE
Set SelMgr = Model2.SelectionManager
Count = SelMgr.GetSelectedObjectCount
If Count <> 1 Then
 swApp.SendMsgToUser "PLEASE SELECT ONE VIEW."
 Exit Sub
End If
Dim configname As String
Set selview = SelMgr.GetSelectedObject5(1)
configname = selview.ReferencedConfiguration
viewpath = selview.GetReferencedModelName
If (LCase(Right(viewpath, 3)) = "prt") Then
swtype = swDocPART
Else
swtype = swDocASSEMBLY
End If
Set Part = swApp.OpenDoc6(viewpath, swtype, 0, configname, e, w)
partitle = Part.GetTitle
Part.ShowConfiguration2 (configname)
retval = Part.Save3(swOpenDocOptions_Silent, e, w)
swApp.CloseDoc partitle
Model2.EditRebuild3
Set Part = Nothing
RE: Editing Dims
Isn't there a setting that is toggled during install for "Allow model edit from drawing" or something like that?
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
RE: Editing Dims
How do I Disable model changes from drawings?  FAQ559-930
RE: Editing Dims
That is set right....it has to do with active configs.  The Drafter having the problems has found a work around....editing the model dims to get text like "2X", and manually putting dims in.
Ed Hulse
RE: Editing Dims
If you make the model configuration being worked on, active, (ie. either open it for viewing, or save it while that config is viewable), then you won't have to manually insert the dimensions.
RE: Editing Dims
I will have him try that
Ed Hulse
