Filament Windig Machines Accuracy Range
Hi;
I Want to know what is the range of filament winding machines accuracy in fiber angles and layer thichness,for example +-0.01 deg ,+-0.01 mm or more.
Thank You Very Much
Thank You Very Much
RE: Filament Windig Machines Accuracy Range
Why do you need this info? What are you trying to do?
I am working on optimization of filament wound pressure vessels.since the design variables are the angle and the thickness of layers i want to know their ranges.
