CRSI retaining wall
CRSI retaining wall
Has anyone worked through the retaining wall examples in the CRSI concrete book. I am having trouble with the stem deflection calculation. I cannot make the units correct. Any suggestions would be appreciated.
RE: CRSI retaining wall
But...
I can not get the units to end up as inches. Numerator is ft^5 times lb/ft^3, leaving ft^2*lb.
Denominator is questionable, but lb/in times in^3, leaving lb*in^2. I think the 30x10^6 has a unit of lb/in.
Numerator divided by denominator becomes unitless.
The examples have a 1728 (which is 12^3) see page 14-17, which is changing feet into inches, but I cannot work the units out.
