wildcard search: error in null values
I have a form that uses a wildcard search, the results of the search are places in a subform. But when Input a word into the search that isn't in the table, the search comes up blank. Heres the code
CODE
Private Sub refresh_Click()
Dim x As String
If IsNull(Me.find) Then
MsgBox "Please enter search criteria.", , "Natural Catalog"
Me.find.SetFocus
Exit Sub
End If
x = "SELECT * FROM Program_Name WHERE Program_Name.Description LIKE "
x = findLibSQL + "'*" + Me.find + "*'"
Me.RecordSource = findLibSQL
If IsNull(x) = True Then
MsgBox "No records matching the criteria", vbExclamation, " Database -Library Search'"
Me.find.SetFocus
End If
End Sub
Please help me with the error, thank you
RE: wildcard search: error in null values
You've set x to be a string:
You then test to see if it's NULL? - it won't be!
You haven't specified what program you're using, but the usual way of doing this would be to construct your query (using the concatenation operator '&' rather than the addition operator '+'), then open a recordset (using conn as your db connection)
Set myRST = conn.Execute(x)
If myRST.EOF Then
Else
Set myControl.Recordsource = myRST
End If
You should also look at using a stored procedure (if you're using a SQL database) or a parameter query (in Access) to avoid the potential dangers of a SQL injection attack, See:
http://search.microsoft.com/search/results.aspx?qu=%22SQL+injection+attack%22&View=msdn&st=b&c=4&s=1&swc=4
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
Steam Engine enthusiasts: www.essexsteam.co.uk
