sum of sum of columns
Hi!
I'm using access and I have 3 tables: "Customers", "Invoices" and "InvoiceItems"
Invoices
Folio    IdCostum
1             1
2             3
3             3
4             2
5             1
6              2
 Customers
IdCostum    Name
1                 John
2                 Steve
3                 Joe
 InvoiceItems
Folio    Item           Total
1       anything          $10
1        anything          $10
2       anything          $30
3       anything          $7
3       anything          $3
4       anything          $50
4       anything          $20
4       anything          $10
5       anything          $15
6       anything          $15
6       anything          $5
6       anything          $5
Column "IdCostum" from "Customers" and "IdCostum" from "Invoices" are linked.
Coumn "Folio" from invoices and "Folio" from "InvoiceItems" are linked  so the total of each Invoice is equal to the sum of
its items. (for example Invoice "1" is equal to $20, Invoice "2" is equal to $30, etc.)
I want to make a query that returns "IdCostum" and "Name" from "Customers" and the Total of  Invoices of each customer like
this
 Query
IdCostum    Name       Totals
1                 John          $35
2                 Steve         $105
3                 Joe             $40
You notice I need to make a sum of sum of columns
How can I make this query?
Thanks!
RE: sum of sum of columns
Here you are:
select customers.idcostum, name, sum(total) as totals from customers
join invoices on customers.idcostum=invoices.idcostum
join invoiceitems on invoiceitems.folio=invoices.folio
group by customers.idcostum, name
the above is also correct, but when i use it in microsoft access/sql, it is not working, so the below code is for micorosoft access ....but you should know how to run this code in microsoft access (there must be relationship between tables).
SELECT Customers.IdCustom, name, sum(total) as Total_Sum
FROM (Customers INNER JOIN invoices ON Customers.IdCustom = invoices.IdCustom) INNER JOIN InvoiceItems ON invoices.Folio = InvoiceItems.Folio
group by Customers.IdCustom, name;
thanks pkgupta9!! it works!!
