Cooling Tower Water Treatment with polymers
I recently heard of a polymer for use in cooling towers that can sequester Ca & Mg to allow much higher cycles of concentration in the tower. This polymer has a very high bonding factor for these elements which allows the cycles of concentration to approach 40 or 50.
Do you have information on the availability of this product?
RE: Cooling Tower Water Treatment with polymers
Each application is unique and require careful analysis. Ca and Mg are two contaminants but are not the only ones.
Follow the advise of Bimr and consult serious suppliers.
rgs
But, yes ... you gotta be using scale inhibiting polymers and corrosion inhibitors .. polymers will be a sound investment unless your make-up water is way too soft (eg: the BC coast?)
Cheers//
Edwin Muller
KW2 Burau Veritas
edwin.muller@nl.bureauveritas.com
