problem with solidify function
I made a solid tube using the variable sweep function. This tube passes though a surface of revolution. When I try to use the 'solidify' function to trim the tube to the surface, the 'trouble shooter' popup appears, and the operation fails. There is a message saying, 'single edged curve' or something to that effect. Any words of wisdom out there?
RE: problem with solidify function
Does it point you to the edge in question?
"By all means, do not use a hammer." (1925 IBM Maintenance Manual)
