Insufficient Virtual Memory Problem
Hello All-
I have a huge file that has an excess of 220,000 nodes (200,000 elements), and each time I run the analysis, I get the Fatal Error S1110, which states the following solution options:
Increase your virtual memory setting (see virtual memory in Windows Help). If this does not
correct the problem, set the Model Initialization directive, RAM, to a smaller value. Most
versions of Windows have a 2 GB limit for a single process. This limit can be reached when
the RAM directive is set above 900 MB. If neither of these actions help, consider selecting the
PCGLSS or VIS solver on the DECOMPMETHOD directive.
I have done all these options, and my model still will not run. Does anyone have a solution besides modifying my model with a coarser mesh?
RE: Insufficient Virtual Memory Problem
2. Set SPARSEITERMODE to 3. This uses the least memory and but you may not get SPC forces, not sure.
3. Windows XP has the ability to access 3GB of RAM and I know NEiNastran supports this mode. I think the process is as simple as putting a /3GB in your boot.ini file but I would ask Noran support about this as they have a file that talks about it. Maybe you can find something on the Microsoft website about the 3GB switch.
4. Make sure you have your page file set to access at least 3GB. This is in Windows under the control panel, system icon, then under performance.
How much virtual and physical memory us being reported in the .log file? Where is it failing with the insufficient memory error (what module)? If you have surface contact this could be an entirely different problem. Let me know and I can tell you how to fix that as well.
FATAL ERROR S1110: INSUFFICIENT MEMORY AVAILABLE TO CONTINUE
VIRTUAL MEMORY = 512342015 WORDS 3908.9 MEGABYTES
REAL MEMORY = 202270208 WORDS 1543.2 MEGABYTES
DRIVE c: DISK SPACE = 3930289152 WORDS 29985.7 MEGABYTES
EXECUTION TERMINATED DUE TO A SYSTEM ERROR
TOTAL WARNINGS = 33
TOTAL FATAL ERRORS = 1
1. Do you have any surface contact in the model?
2. Did you try making the settings in #1 in my original message and did that work?
