AutoCAD Blocks
AutoCAD Blocks
I am seeking a supplier of Mechanical Engineering blocks for items such as bearings, circlips, springs, motors, gearboxes, Nuts and Bolts etc. These are readily available I know but in my case I require that each block come with at least the 3 standard views and in some cases a section view. Can anyone please assist me?
Thanking You.
Thanking You.
RE: AutoCAD Blocks
"Everybody is ignorant, only on different subjects." — Will Rogers
RE: AutoCAD Blocks
Many Thanks
RE: AutoCAD Blocks
www.partspec.com and you get redirected (they only guarantee good results with Internet Explorer but I have used FireFox and it seems ok).
RE: AutoCAD Blocks
It also works with Firefox. It does seem to contain what I want for the students in my drawing class. Once again Many thanks for your help.
