2006 graphics performance
just installed 2006, and it works all right, but the graphics performance is down at least 50%. Anyone experienced this? The settings are the same as for 2005. This seems to be the problem for all the later versions of SW, serious degradation in performance every time. Tried installing the newest approved drivers (listed on the nvidia site as approved at least) but no difference in performance. Any tips and tricks out there?
Best regards, Mindnumb.
RE: 2006 graphics performance
I have a process that seems to be much better and it's not very time consuming or hard to do.
1) Uninstall all drivers
2) Reboot
3) Install latest Certifed driver for your Card
4) Reboot
5) Test
IF you are still seeing performance lost, then I am sure there maybe something else causing this. Such as TEMP file to large, etc... check out the FAQ for futher options of the possible problem.
Also test your files out on another system - If you don't have one there, contact your VAR and have them test the file.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Maybe your video card settings changed? For instance FSAA can really slow SW down...
Stefan Hamminga
Mesken BV
2005 Certified SolidWorks Professional
Mechanical designer/AI student
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
FSAA: "Full Screen Anti Aliassing"
AF: "Anisotropic Filtering"
Both have a severe impact on your 3D performance
Stefan Hamminga
Mesken BV
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
I began to notice performance issues with my FX-500 when I began using larger and larger assemblies. This has been an increasing factor that 2006 clarified. So I'll upgrade the graphics card along with the processor and RAM on my next system build.
Hey, if the software is increasingly capable of providing more, it will certainly do so at the expense of hardware to match. This isn't MS Word--you can build anything you want with this software. Ten years ago, the smallest CPU box I'd ever seen do something like this was the size of a small refrigerator and cost $120K to set up. I'd say we're better than par for the course.
Jeff Mowry
And to your information: my system setup is as follows:
pentium4 3,2ghz , 2 Gig ECC Ram, Quadro fx1000 graphics card.
2 Sata disks on separate controller in Raid-0.
