Autocad in Photoshop
Hello.
Do you know how to obtain a quality drawing of Autocad in Photoshop??
I ask because I want to add some colours on my Autocad plan.
Thanks for your help.
RE: Autocad in Photoshop
David
But then when you have the autocad plan in photoshop in a .pdf file, how do you print it at the good scale (the same scale as in Autocad)?
PS: I use Indesign too to put the .pdf files on the pages to print. But how do I obtain the drawings at the same scale as in Autocad?
Thanks for your answer again.
It works that way with printers too. I can send a .pdf from AutoCad to "E" size with no jaggy's.
Within Photoshop you can edit the file, save it back as a .pdf, .psd, or .jpg all of which are scaleable on output. Some print shops have a problem with the .psd format which is unique to the PhotoShop family.
David
if you have a drawing in Autocad at the scale 1/100 for example, when you export it in .pdf in photoshop, how can you print this drawing at the scale 1/100 too?
