Help required with coupled-thermo-structural analysis
hi i am doing a moving heat source thermo-structural analyis. i used sfe command in a doloop to apply heat. now when i am using ldread in the do loop to read the rth file it is not applying loads properly. can anyone provide me with example codes of transient-thermal structural analysis. also if any one cud tell me the exact way of coupling thermal results to struture. it would really be great.
thanx
thanx
RE: Help required with coupled-thermo-structural analysis
harry
