damping ratio effect in single point response analysis
Hi
I am doing a single point response analysis for a shell model and I observed that the damping doesnot affect the results at all.
Can anyone provide some thoughts on why this is happening?
thanks
regards
james
RE: damping ratio effect in single point response analysis
Are you using an applicable form of damping for your SPRS analysis? (DMPRAT for example?)
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
yah.i was told that damping ratio is used only to interpolate between the curves, it has no effect on the response. In other words, if u change damping ratio from 0.1 to 1.0, you will not see any diff in results
james
