parylene coatings?
parylene coatings?
I'm looking for a thin coating for brass and aluminum transducer housings that will protect the base material from saltwater corrosion. It will be sealed to a housing via o-rings (surface finish matters) and will house (via epoxy or urethane fill) electronics. Has anyone worked with parylene for this type of application or have suggestions?
RE: parylene coatings?
Mike Halloran
Pembroke Pines, FL, USA
