Pressure piping in Brewery Plant
What is applicable code for pressure piping to be installed in brewery plant in New Brunswick province of Canada.
RE: Pressure piping in Brewery Plant
It depends on what pressure piping? Steam, air, CO2 etc. B31.1, B31.3, or B31.5??
Many thanks for you prompt response.I agree pressure piping based on service must be designed, fabricated and installed in accordance with B31.1 ( Power Piping ), B31.3 ( Chemical plant ) and B31.5 (Refrigation) This complies with New Brunswick regulation for Boiler and Pressure Vessel Act.We can not use any other code like DIN or BS.
For economy reasons, for non pressure piping and fittings can we use German / BS Code.
I was a past inspector for the boilers branch in New Brunswick. I would avoid anything but the specified standard listed in Regulation.
If it's non pressure then use what makes sense.
Thanks for your valuable tip.
In New Brunswick ,Do we need registration for air piping smaller then 3/4" and 1/4" and CRN number for air hoses of 3/4" and 1/4".
Thank you in advance for prompt response to this request
Contact your speciaist dairy tube and fittings company and ask them. Some of the hygeinic fittings are non standard and thus require some derating or testing to qualify for design to a code designed for boilers or petrochem. Again those in the industry will know. Here in Australia we have Alfa Laval etc who are industry leaders.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
