120/240 Underground Service w/Double Aluminum Conductors
I need to run an underground service (120/240 single phase three wire,200amp) approx. 400' from meter to panel.Because of voltage drop and budget issues (copper$ vs. Aluminum$) I am looking at doubling the number of conductors with Aluminum wire. For example; 2-4/0 for leg A 2-4/0 for leg B and 2-2/0 for the Neutral . All these conductors would be run in 4" pvc conduit. Is there any unforeseen problems with this configuration ?
Thanks, rlharch
Thanks, rlharch
RE: 120/240 Underground Service w/Double Aluminum Conductors
Thanks for your input. Termination at the meter should not pose a problem since there are three lugs per leg and also at the neutral . Any suggestions on termination at the Panel side?
Thanks again, rlharch
The main thing is that you need a termination solution that is UL approved and does not violate the UL-listing of the panelboard (if you're an anal-retentive engineer like me, anyway.)
