Cannot Select Lines in Alternate Positions
SWX 2005 SP4.0
I have a plan view in my assembly which has an alternate position view in it.  Yesterday I put a couple dims from a detail in the alternate position to one in the main view.  Now today when I go to put more dims in, I cannot select the lines in the alternate position at all but I can pick the lines in the regular view.  I cannot think of anything that I might have done to make this happen. I have also tried deleting the alternate position and putting it back in, ans it still won't let me select.
Does anyone know what might be wrong?
RE: Cannot Select Lines in Alternate Positions
How was the 'alternate' view created?
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
I've had similar problems with alternate views.  Usually goes away after a reboot.
I created the alternate view by clicking in the plan view, hitting the alternate view button and selecting my other configuration.  The weird thing is that I can select the alternate views, of the same config, in all of the other views just not the plan view.
I tried the reboot and that didn't work.
Try sending a Rx to your VAR.
Chris
FAQ559-1100
FAQ559-716
