Forced fields (properties) before saving
Is it possible to create a few forced fields in the properties-section? I mean a scenario "as long as the forced fields are empty you don't have the posibility to save", or more likely a popup with the properties witch are still empty.
Can I make this with the Visual Basic part of SE
RE: Forced fields (properties) before saving
Made you should make it a fine when they forget, dock it from their paycheck!! ;)
bc
