Car body modification
Anyone knows what type of tests are made over a car transformed into a cabriolet. I means tests to check if the structure, after cuts and strengthening, is able to withstand the efforts. Static and dynamic tests if they exist.
RE: Car body modification
*Without data, you're just another person with an opinion.*
Hydroformer
Then you'd do durability.
There's also functional things like water leaks, soft top durability, vision, etc etc.
Cheers
Greg Locock
